Configuring pinmux in am335x (beaglebone) can't be done from user mode
Hi all, I've been experimenting with seL4 running on a Ninjablocks (https://www.engadget.com/2013/05/01/ninja-blocks/) that I had lying around. Inside there is a beaglebone, with a custom shield (or cape) containing a microcontroller (atmega328p), some LEDs and a radio. The beaglebone (which normally runs linux) sends json-encoded commands over a serial connection to the on-cape microcontroller, which runs firmware that decodes these commands and controls the LEDs and radio. The complication is that the am335x pins connected to the custom shield are multiplexed, and don't connect to a uart device by default (they are gpio pins by default). The "Control Module" in the am335x can be used to configure pin multiplexing, but it can't be written to in user-mode. From the am335x manual (http://www.ti.com/lit/ug/spruh73q/spruh73q.pdf, page 1449): "Note: For writingto the controlmoduleregisters,the MPUwill need to be in privileged modeof operationand writes will not work fromusermode." To test that the rest of my app works I added the control module to the beaglebone device tree overlay and hacked the kernel to configure the relevant pins to connect to the uart device during boot: https://github.com/stevebob/seL4/commit/4295035ac7fd720fb531b7e0893f1f1191ec... And now I have a little rootserver that can control the colours of LEDs on the shield: https://github.com/stevebob/sel4ninja/blob/master/apps/hello-ninja/src/main.... What would be the right way of configuring the control module in a seL4-based system, given that it has to happen in kernel mode? To configure the uart pins when running linux on the board, I had to add the following to the device tree: scm@0 { ... pinmux@800 { ... pinmux_uart0_pins { // <-- this was already here pinctrl-single,pins = <0x170 0x30 0x174 0x00>; phandle = <0x20>; }; pinmux_uart1_pins { // <-- I had to add this pinctrl-single,pins = <0x180 0x30 0x184 0x00>; phandle = <0x60>; }; The (seL4) kernel build system already has basic support for interpreting device trees. Would a reasonable solution to my problem be extending this support with a minimal statically-generated control module driver that configures pinmux during boot based on the device tree? There would still be a problem where each board could only have a single pinmux config (as specified by that board's device tree). It seems like an easy fix for this would be a config variable passed to the build system (similar to -DPLATFORM) that overrides the default device tree file. That way projects that want non-standard pinmux configs could bring their own device trees. Cheers, Steve
participants (2)
Mcleod, Kent (Data61, Kensington NSW) -
Stephen Sherratt
